Unroll
Revision as of 21:57, 28 September 2022 by Daniel (talk | contribs) (→Cylinder)
Cylindrical shape to unroll
Cylindrical shape unrolled
Unrolled cone
Cylinder
'Unroll cylinder' dialog
  • cylinder radius
  • and optionally a point on the axis (otherwise CloudCompare can try to guess it by computing the gravity center of the point cloud)
Cone
'Unroll cone' dialog
Straightened cone
