Unroll
Revision as of 21:58, 28 September 2022 by Daniel (talk | contribs) (→Cylinder)
Cylindrical shape to unroll
Cylindrical shape unrolled
Unrolled cone
Cylinder
'Unroll cylinder' dialog
  • cylinder radius
  • since version 2.11, it is also possible to specify the angular range (by default it's [0-360], but you can input any angular value, and even multiple revolutions)
Cone
'Unroll cone' dialog
Straightened cone
