Unroll
Revision as of 22:00, 28 September 2022 by Daniel (talk | contribs) (→Cylinder)
Cylindrical shape to unroll
Cylindrical shape unrolled
Unrolled cone
Cylinder
'Unroll cylinder' dialog
  • cylinder radius
Cone
'Unroll cone' dialog
Straightened cone
