Edit\Subsample
Revision as of 08:19, 20 February 2023 by Daniel (talk | contribs)
This tool is accessible via the 'Edit > Subsample' menu, or via the icon in the upper main toolbar.
Several subsampling methods are available:
  • random
  • spatial
  • octree-based
  • for each input cloud, a new subsampled cloud is created (the original one is simply deactivated)
  • a subsampled cloud is a subset of the input cloud (the original points are not displaced)
  • thanks to this, a subsampled cloud keeps the features of its source cloud (scalar fields, colors, normals, etc.)
Subsampling dialog
Random
Subsampling 'Random' parameters
Spatial
How the algorithm works: points are parsed in a somewhat arbitrary order (spatially organised by the octree). The very first point is flagged as 'to be kept'. Then, for each subsequent point in the cloud, we query its neighbors within the specified radius. If no neighbor point is already flagged as 'to be kept', we also flag this new point as 'to be kept'. In the end, only points flagged as 'to be kept' will be part of the output cloud.
Use active SF (option)
Original cloud with a scalar field proportional to the local curvature
Subsampling 'Spatial' parameters based on the active scalar field values
Subsampling output
Octree
  • the higher the level is, the smaller the cells are (so the more points you'll keep)
  • the maximum octree level is 10 in the 32 bits version of CloudCompare, and 21 in the 64 bits version.
  • the tool differs from the 'Octree > Resample' method. The Resample tool computes the center of gravity of the points falling in each cell (i.e. the created cloud is not a subset of the original cloud)
