Unroll
- define a custom 3D axis
- init the unrolling parameters with an existing cylinder or cone entity present in the database
- output the unrolled cloud in an arbitrary coordinate system
Cylinder
- cylinder radius
Cone
- Conical
- Cylindrical (fixed radius)
Main parameters are:
- span ratio
- start and stop angles
Straightened cone
Export deviation scalar field
