Unroll
Revision as of 17:43, 6 February 2025 by Daniel (talk | contribs) (Cylinder)
Cylindrical shape to unroll
Cylindrical shape unrolled
Unrolled cone
  • define a custom 3D axis
  • init the unrolling parameters with an existing cylinder or cone entity present in the database
  • output the unrolled cloud in an arbitrary coordinate system
Cylinder
'Unroll cylinder' dialog
Main parameters are:
  • cylinder radius
Cone
  • Conical
  • Cylindrical (fixed radius)
'Unroll cone' dialog
  • span ratio
  • start and stop angles
Straightened cone
Export deviation scalar field
