Unroll
Revision as of 17:47, 6 February 2025 by Daniel (talk | contribs)
Cylindrical shape to unroll
Cylindrical shape unrolled
Unrolled cone
Cylinder
'Unroll cylinder' dialog
Main parameters are:
  • cylinder radius
Cone
  • Conical
  • Cylindrical (fixed radius)
'Unroll cone' dialog
  • span ratio
  • start and stop angles
Export deviation scalar field
Output unrolled cloud in an arbitrary coordinate system
  • X: unroll angle
  • Y: distance to primitive
  • Z: longitude
