Segmentation tool, cuts ahead and behind...
Something that kills me is that the segmentation tool cuts in front and behind the camera, when trimming road scan data which is very dense and you're trimming like "inside" of the cloud, that is a pain. Would it be very complicated to trim only visible points?
Re: Segmentation tool, cuts ahead and behind...
Normally it shouldn't if you are in perspective mode?
Yes in perspective, because otherwise I can´t get "within" the cloud to do cleanups
Hum, indeed it doesn't work anymore... I had the impression that this had been fixed a while ago. Would you be able to open a 'bug' (issue) on github?
