Better support for photomosaic/photogrammetry by non-rigid transform/deformation
PJS
Post by PJS »
Thank you for a great tool!
In some cases of photomosaic, e.g. mono-camera image set of a landscape, I experience that various photogrammetry pipelines result in 3D models with an unnatural bent shape. For example, output from a segment of a lawn-mower pattern from a drone flying over a flat landscape may result in a curved output, even though the ground was perfectly horizontal.
I did a search in the forum of "rigid" and found a couple of threads, where the answers were that non-rigid alignment is not currently a part of CC.
As far as I understand, non-rigid registration/alignment/deformation of point clouds are kind of open research questions.
Do anyone know if any methods are working to a level where they could be implemented as plugins to CC?
/PJS
