New plugin - tutorial
adams
Post by adams »
Have u got any tutorial "how make new plugin to CC"?
I have some idea, but i'm not professional programmer, so i need some advices to do it :)
I wanna make plugin with other Variants of the ICP Algorithm.
What do u think about it?
Cheers,
Adam
Re: New plugin - tutorial
Please look at https://github.com/cloudcompare/trunk/b ... plugin.rtf. And generally the best way to learn is to look at plugins with a similar workflow.
Otherwise there are other discussions on the forum about this subject. And of course you can ask more questions here.
adams
Post by adams »
Ok, thanks for advice. I will check it.
I have other question
I'm trying to write some scripts in python and i have real problem with this function:
ICP for 2 clouds > i get .txt file with matrix
Then i would like to use this matrix again for other cloud, but i still got error message
"Failed to read transformation matrix file
'test_3_L2__REGISTRATION_MATRIX_2015-11-27_00h06.txt' "
I tried to change name of .txt file, but it still doesn't work
It's part of my script in python:
openFile=os.system("CloudCompare -AUTO_SAVE OFF -O -GLOBAL_SHIFT -450000 -450000 0 " + filePath1
+ " -CROP2D Z " + text + " -O -GLOBAL_SHIFT -450000 -450000 0 " + filePath2 + " -ICP " +
" -CLEAR_CLOUDS " + " -O -GLOBAL_SHIFT -450000 -450000 0 " + filePath1 + " -APPLY_TRANS " + fpath )
fpath is the name of .txt file
Have you tried providing the full path to the transformation maybe?
Otherwise can you post the file contents?
TommyMager
Post by TommyMager »
Hi! I'm not a professional programmer, either. Need few tips on CC plugins. The link above is dead.
Indeed, here is the new link / document:
https://github.com/CloudCompare/CloudCo ... IBUTING.md
