Logic to reorient all faces.
Sha11
Post by Sha11 »
I have an mesh file (.off) , faces are not oriented corehently ( i mean some triangles have cyan color while other have "green" ). Is there any way to reorient them ( i mean all triangles shows in "green' color. )
These are below two test cases (.off).
https://justpaste.it/62ajc
https://justpaste.it/5gf7j
Re: Logic to reorient all faces.
Maybe Meshlab has some built-in functions to do that?
Sha11
Post by Sha11 »
Hmm , I know that , but I want some logic to to this.
Do you know about any open source project that solve this type of problem...
Or any logic..???
Meshlab is open source ;)
Otherwise if you have the mesh topology, you can 'propagate' the direction of a normal from one triangle to its neighbors (with a kind of Minimum Spanning Tree structure for instance) or other front propagation methods.
Sha11
Post by Sha11 »
Ok I will try this..
