Scalar represent a kind of density inside a point cloud
Posted: Tue Jan 23, 2024 11:13 am
by mariolino
is there a function in CloudCompare or is it possible to create one with the goal of adding a scalar for each point within a cloud that represents the minimum distance calculated from that point to the nearest point (excluding for each point the calculation with respect to itself) within the same cloud ?
Do you have any suggestions or guidance on this ?
This calculation should locally represent a kind of density of the point cloud ......
Thank you,
Mariolino
Re: Scalar represent a kind of density inside a point cloud
Posted: Tue Jan 23, 2024 12:26 pm
by HeadLess
Tools - > other -> compute geometric features (density number of neighbours)
It won't give distence of closest point, instead it gives a number of points inside a given radius.
Posted: Tue Jan 23, 2024 1:03 pm
by mariolino
thanks for the response, that command I know but without the generation of the scalars representing the distance to the nearest point is not very useful to me......
Posted: Tue Jan 23, 2024 8:59 pm
If you want the distance to the closest point then you could use the 'Approximate density' in the older versions of CC (see https://www.cloudcompare.org/doc/wiki/index.php/Density)
Posted: Thu Jan 25, 2024 8:11 am
by mariolino
Daniel many thanks for all,
for the advice I tried in the previous version the command you suggested unfortunately was not what I was hoping for ...
but with a few lines of code with the Python plugin by Thomas Montaigu + SciPy I was able to generate the scalar which is particularly useful for identifying outlier points.
