CCCoreLib 31 May 2022
CloudCompare Core algorithms
Cloud-to-cloud 'nearest neighbors' distances computation parameters. More...
#include <DistanceComputationTools.h>
Public Member Functions | |
Cloud2CloudDistancesComputationParams () | |
Default constructor/initialization. | |
Public Attributes | |
unsigned char | octreeLevel |
Level of subdivision of the octree at witch to apply the distance computation algorithm. More... | |
ScalarType | maxSearchDist |
Maximum search distance (true distance won't be computed if greater) More... | |
bool | multiThread |
Whether to use multi-thread or single thread mode. More... | |
int | maxThreadCount |
Maximum number of threads to use (0 = max) | |
LOCAL_MODEL_TYPES | localModel |
Type of local 3D modeling to use. More... | |
bool | useSphericalSearchForLocalModel |
Whether to use a fixed number of neighbors or a (sphere) radius for nearest neighbors search. More... | |
unsigned | kNNForLocalModel |
Number of neighbors for nearest neighbors search (local model) More... | |
ScalarType | radiusForLocalModel |
Radius for nearest neighbors search (local model) More... | |
bool | reuseExistingLocalModels |
Whether to use an approximation for local model computation. More... | |
ReferenceCloud * | CPSet |
Container of (references to) points to store the "Closest Point Set". More... | |
ScalarField * | splitDistances [3] |
Split distances (one scalar field per dimension: X, Y and Z) | |
bool | resetFormerDistances |
Whether to keep the existing distances as is (if any) or not. More... | |
ReferenceCloud* CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::CPSet |
The Closest Point Set corresponds to (the reference to) each compared point's closest neighbor.
unsigned CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::kNNForLocalModel |
For local models only (i.e. ignored if localModel = NO_MODEL). Ignored if useSphericalSearchForLocalModel is true.
LOCAL_MODEL_TYPES CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::localModel |
Default: NO_MODEL. Otherwise see CC_LOCAL_MODEL_TYPES.
ScalarType CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::maxSearchDist |
Set to -1 to deactivate (default).
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::multiThread |
If maxSearchDist > 0, single thread mode will be forced.
unsigned char CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::octreeLevel |
If set to 0 (default) the algorithm will try to guess the best level automatically.
ScalarType CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::radiusForLocalModel |
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::resetFormerDistances |
By default, any previous distances/scalar values stored in the 'enabled' scalar field will be reset before computing them again.
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::reuseExistingLocalModels |
For local models only (i.e. ignored if localModel = NO_MODEL). Computation is much faster but less "controlled".
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::useSphericalSearchForLocalModel |
