CloudCompare 3D entities
Public Types | Public Member Functions | Protected Attributes | List of all members
ccOctreeFrustumIntersector Class Reference
Collaboration diagram for ccOctreeFrustumIntersector:
Public Types
enum  OctreeCellVisibility { CELL_OUTSIDE_FRUSTUM = 0 , CELL_INSIDE_FRUSTUM = 1 , CELL_INTERSECT_FRUSTUM = 2 }
 Definition of the state of a cell compared to a frustum. More...
 ccOctreeFrustumIntersector ()
 Default constructor.
bool build (CCCoreLib::DgmOctree *octree)
 Prepares structure for frustum filtering.
OctreeCellVisibility positionFromFrustum (CCCoreLib::DgmOctree::CellCode truncatedCode, unsigned char level) const
 Returns the cell visibility.
void computeFrustumIntersectionWithOctree (std::vector< std::pair< unsigned, CCVector3 > > &pointsToTest, std::vector< unsigned > &inCameraFrustum, const float planesCoefficients[6][4], const CCVector3 ptsFrustum[8], const CCVector3 edges[6], const CCVector3 &center)
 Compute intersection between the octree and a frustum and send back the indices of 3D points inside the frustum or in cells intersecting it. More...
void computeFrustumIntersectionByLevel (unsigned char level, CCCoreLib::DgmOctree::CellCode parentTruncatedCode, OctreeCellVisibility parentResult, const float planesCoefficients[6][4], const CCVector3 ptsFrustum[8], const CCVector3 edges[6], const CCVector3 &center)
 Compute intersection between the octree and the height children cells of a parent cell. More...
OctreeCellVisibility separatingAxisTest (const CCVector3 &bbMin, const CCVector3 &bbMax, const float planesCoefficients[6][4], const CCVector3 frustumCorners[8], const CCVector3 frustumEdges[6], const CCVector3 &frustumCenter)
 Separating Axis Test. More...
CCCoreLib::DgmOctree * m_associatedOctree
std::unordered_set< CCCoreLib::DgmOctree::CellCode > m_cellsBuilt [CCCoreLib::DgmOctree::MAX_OCTREE_LEVEL+1]
std::unordered_set< CCCoreLib::DgmOctree::CellCode > m_cellsInFrustum [CCCoreLib::DgmOctree::MAX_OCTREE_LEVEL+1]
std::unordered_set< CCCoreLib::DgmOctree::CellCode > m_cellsIntersectFrustum [CCCoreLib::DgmOctree::MAX_OCTREE_LEVEL+1]
Member Enumeration Documentation
◆ OctreeCellVisibility
OUTSIDE : the celle is completely outside the frustum (no intersection, no inclusion) INSIDE : the cell is completely inside the frustum INTERSECT : other cases --> the frustum is completely inside the cell OR the frustum and the cell have an intersection
Member Function Documentation
◆ computeFrustumIntersectionByLevel()
void ccOctreeFrustumIntersector::computeFrustumIntersectionByLevel ( unsigned char  level,
const CCVector3 &  center
levelcurrent level
parentTruncatedCodetruncated code of the parent cell (at level-1)
parentResultcontains in which class the parent cell has been classified (OUTSIDE, INTERSECTING, INSIDE)
planesCoefficientscoefficients (a, b, c and d) of the six frustum planes (0:right, 1:bottom, 2:left, 3:top, 4:near, 5:far)
ptsFrustum3D coordinates of the eight corners of the frustum (global coordinates system)
edges3D coordinates (global coordinates system) of the six director vector of the frustum edges
center3D coordinates of the frustum center (global coordinates system) ; this is the center of the circumscribed sphere
◆ computeFrustumIntersectionWithOctree()
void ccOctreeFrustumIntersector::computeFrustumIntersectionWithOctree ( std::vector< std::pair< unsigned, CCVector3 > > &  pointsToTest,
std::vector< unsigned > &  inCameraFrustum,
Every cells of each level of the octree will be classified as INSIDE, OUTSIDE or INTERSECTING the frustum. Their truncated code are then stored in m_cellsInFrustum (for cells INSIDE) or m_cellsIntersectFrustum (for cells INTERSECTING).
pointsToTestcontains the indice and 3D position (global coordinates system) of every 3D points stored in an INTERSECTING cell
inCameraFrustumcontains the indice of every 3D points stored in an INSIDE cell
◆ separatingAxisTest()
ccOctreeFrustumIntersector::OctreeCellVisibility ccOctreeFrustumIntersector::separatingAxisTest ( const CCVector3 &  bbMin,
const CCVector3 &  bbMax,
const CCVector3 &  frustumCenter
See "Detecting intersection of a rectangular solid and a convex polyhedron" of Ned Greene See "OBBTree: A Hierarchical Structure for Rapid Interference Detection" of S. Gottschalk, M. C. Lin and D. Manocha
bbMinminimum coordinates of the cell
bbMaxmaximum coordinates of the cell
frustumCorners3D coordinates of the eight corners of the frustum (global coordinates system)
frustumEdges3D coordinates (global coordinates system) of the six director vector of the frustum edges
frustumCenter3D coordinates of the frustum center (global coordinates system) ; this is the center of the circumscribed sphere
