Volume calculation
Adam
Volume calculation
Post by Adam »
I'm using the volume calculation to calculate volume loss.
If I change the step value, I keep having a different volume. what is the step stand for? what is the best value in the case below? thank you
Step value 2.000000
Volume: -27.029
Surface: 9,760.000
Added volume: (+)114.202
Removed volume: (-)141.231
Matching cells: 98.2%
Non-matching cells:
ground = 0.7%
ceil = 1.1%
Average neighbors per cell: 7.8 / 8.0
Step value 1.000000
Volume: -17.811
Surface: 9,486.000
Added volume: (+)147.880
Removed volume: (-)165.691
Matching cells: 97.5%
Non-matching cells:
ground = 0.9%
ceil = 1.6%
Average neighbors per cell: 7.9 / 8.0
Step value 0.5000000
Volume: -8.526
Surface: 9,368.250
Added volume: (+)183.858
Removed volume: (-)192.384
Matching cells: 97.4%
Non-matching cells:
ground = 1.1%
ceil = 1.5%
Re: Volume calculation
The step value defines the resolution of the raster grid that is used to estimate the volume.
The coarser / bigger it is, the less accurate the result will be. Therefore you should aim for the smallest step possible. However, you will be limited by the density of your clouds. Pay attention to the average neigbors per cell percentage. It should stay close to 8 otherwise it means that holes are appearing between the cells and it will give a wrong volume estimate.
Adam
Post by Adam »
Thanks for your reply. I always get Average neighbours per cell: 7.9 / 8 or 7.8/8. Does it mean I'm on the safe side?
How about Matching cells percentage? the higher the better and does this mean CC found the same cells on both clouds?
I also have posted a topic about M3C2 parameters in the question thread, there are some questions please look at them
Yes 7.8 is still safe.
And regarding the matching cells percentage, it's indeed the number of cells that have a matching cell in the other grid. However it only indicates how well the two clouds overlap. There's no particular reason to use it as a criteria when changing the step size.
anagellerramser
Post by anagellerramser »
Hi Adam, I am trying to do something similar, but I want to calculate the volume of plant that I lost, could you tell me if this tool worked for you? How you exported the volume information?
DA523
Post by DA523 »
It worked for me in serveral shapes...
You mean export volume result in text or result volume as pointscloud?
Can you share 2 pc as example
anagellerramser
Thank you for answering.
Ok, so, I'll try to explain better. I have two point clouds, one represents my plot of soybeans before cutting, and the other after having cut 6ft of soybeans, I'm trying to calculate the volume of this "hole" (part in red in the image) left by the cut comparing the two clouds, however with the volume tool, the exported cloud is the height difference tool, the tool only gives the volume value in the box, I'm trying to export the volume information to Excel, or another program. I transformed this height cloud into a raster and imported it into Qgis to calculate the volume, but I'm also unsure about the size of the step, how did you choose the value of this parameter? And how did you get the final volume information? I have 2,000 clouds to calculate.
Another thing that is weird is that the relative height scalar says the red part is 18, maybe centimeters, compared to the ground, but the soybeans were bigger than this.
The volume calculation between the point clouds.
The two point cloud aligned.
two pointcloud.png (57.18 KiB) Viewed 27040 times
The orthomosaic.
The orthomosaic.
this is my orthomosaic.png (158.62 KiB) Viewed 27040 times
DA523
Post by DA523 »
Use leave it empty otherwise you can get wrong results
Start with small grid then increase until shape of grid is regular and volume is stable
This is OK
This is not OK because alot of holes , grid is too small compared to cloud density
You can check attached file for easy testing
volume.zip
(188.84 KiB) Downloaded 1915 times
DA523
Post by DA523 »
I am not sure about CC command line to calculate volume ??
but the hard way but efficient is to use Windows batch file and AutoHotKey free software to automate volume calculation and saving etc ...
anagellerramser
Got it, thank you for your help.
