Noises
kozolins
Noises
Post by kozolins »
Hi!
I have made point cloud from historical satellite images (Corona), but there are different size of "noises" with extreme low height values (because of cloudiness). I tried noise filtering feature, but the result is quite similar to original point cloud and noises still exist. I tried filtering with 15, 30, 50 and 100m radius. Image resolution is 2m. Maybe someone can help?
Kriss
Re: Noises
Could you post a snapshot of your point cloud maybe?
kozolins
Re: Noises
Post by kozolins »
Yes, so this is how point cloud and DEM looks:
The attachment DEM.PNG is no longer available
kozolins
Re: Noises
Post by kozolins »
Point cloud.PNG (352.76 KiB) Viewed 15192 times
Re: Noises
And where is the noise? Can you show the cloud from the side maybe?
kozolins
Re: Noises
Post by kozolins »
Hope you can understand from this - on the right side are negative values.
Re: Noises
Hum, I fear the noise is too dense and 'attached to the cloud'...
You could of course remove the points with negative Z easily, but I bet it's not that easy?
