bare earth extraction - simplified method
hds_surveyor
Post by hds_surveyor »
Hi Daniel
I was thinking of a simplified method of bare earth extraction that uses the octree structure:
1) define a level of octree subdivision
2) divide the point cloud into columns of octree cells and choose the lowest point of the lowest octree cell of each column
3) create a new point cloud with points selected in step 2
it should be a quick and easy way to remove sparse vegetation, people, cars and vertical or overhanging objects from scans
Alberto
Re: bare earth extraction - simplified method
I think the method already exists: it's in "Tools > Projection > Height grid generation".
This method let's you decide of a regular grid step (~ level of subdivision), an orientation (X, Y or Z) and then projects all points in 2D along this orientation, keeping only one point per grid cell. You can eventually choose which point is kept each time (max, mean or min altitude - the latter one will correspond to your proposition).
I believe some users already use it to extract bare earth from aerial lidar data with it.
Thanks for the suggestion anyway (and tell me if I missed something!).
hds_surveyor
yes, something like this
hds_surveyor
the heigh grid generator forces the creation of a regular grid, can you only sample the existing points?
Good idea. We should add an option to do this with the Height Grid Generation tool. I'll add this to the TODO list.
hds_surveyor
thanks Daniel
Ok that's done! It will be available in the next release (and it's already available on the github's trunk for those who compile the project).
hds_surveyor
thanks again, I'll wait for the next release
AndrewRoberts
Post by AndrewRoberts »
Does the height grid generation tool still exist? I do not see it under tools > projections.
Dimitri
Post by Dimitri »
Yes, it's now called "rasterize" and it is much more evolved than the Height grid generation.
