That's after I did an SOR operation on the point cloud and then matched the bounding box centers and scales. As you can see the point cloud needs to be rotated on multiple axes fairly far. ICP does not work in this case - it never gets the alignment even close to correct. I tried the "compute best registration RMS matrix" in the Sand box section under Tools, but that did not work either.
Is there a set of operations that might work in this case? Or am I basically out of luck? Thanks for any help!
