Win64 can't open cc after compiling, it shows 0xc0000142
All about Windows versions
xiaolu
Post by xiaolu »
My compiled environment:
Win10 x64
Inte|(R) Core(TM) 17-9700 CPU @ 3.00GHz (8 CPUs), ~3.0GHz
DirectX 12
Intel(R) UHD Graphics 630
cmake3.20.5
qt5.9.1
vs2017 x64
cloudcompare2.11.3
1. Create a folder in the d drive as shown in the figure
2. Select this in cmake
Click on configure and generate
3. Find the sln file in the build folder and open it with vs2017
Right click all_build and click regenerate
Right-click ALL_BUILD, click Regenerate
4. I get this in the file
Double-click to open and display
In windows event viewer, it shows this.
can you help me
xiaolu
Re: Win64 can't open cc after compiling, it shows 0xc0000142
Post by xiaolu »
the last picture
xiaolu
Post by xiaolu »
But I compiled cloudcompare2.10.2 in the same way and it worked.
xiaolu
Post by xiaolu »
Today I was able to compile and run successfully with qt5.12.5.
But I am using qt5.9.1 in linux, I need to port the program to windows, in order to avoid unnecessary trouble, I still hope I can compile with qt5.9.1 successfully.............
xiaolu
Post by xiaolu »
I tested it today
cc2.10.3 qt5.9.1 works
cc2.11.3 qt5.9.1 not work
cc2.11.3 qt5.9.2 works
I think it's because cc2.11.3 and qt5.9.1 are in conflict.
But I don't know exactly what's wrong.
Please tell me why :(
thanks~
Frankly, I have no idea...
daerzhimeng
Post by daerzhimeng »
xiaolu wrote: Fri Jul 02, 2021 8:49 am I tested it today
thanks~
I use cc2.11.3 qt5.9 not work and have the same issue like yours.
Have you solved the issue please?
xiaolu
Post by xiaolu »
no ,
i use cc2.11.3 with qt5.9.2 .
