Hi everyone,
I am relatively new to CloudCompare but I am trying to export Planes info via command line.
None of the Commands in this documentation (https://www.cloudcompare.org/doc/wiki/i ... _line_mode) do the trick (I think).
Can somebody steer me in the right direction.
Anyways thanks already!
Run Tools -> Batch Export -> Export Planes info in Command Line
JensSlofstra
Re: Run Tools -> Batch Export -> Export Planes info in Command Line
Ah that's probably because this function has not been ported to the command line mode... You would need to add some code to make it accessible (see https://github.com/CloudCompare/CloudCo ... mmands.cpp)
