Convert vertical datum in CC
Liang
Post by Liang »
I'm interested in using CloudCompare to validate my glacier's 3D models in point cloud (PC) format. The vertical datum of my models is WGS84 ellipsoid, but the reference PC (which I converted from a DEM to a point cloud) is in EGM2008 orthometric/geoid height. I'm wondering if there is a way to convert the PC's vertical datum from WGS84 ellipsoidal height to EGM2008 orthometric/geoid height.
I believe it might involve using a transformation matrix, but I'm not sure how to calculate the matrix. If anyone has insights or suggestions on this matter, I would greatly appreciate it!
Thank you in advance for your assistance!
Re: Convert vertical datum in CC
Sadly, CC does not handle coordinate systems... Maybe the GDAL and PDAL suites might help you?
DA523
Post by DA523 »
What about UTM coordinates cc handling.?
What do you mean?
Liang
Post by Liang »
Thanks for the reply!
Eventually, I decided to convert my reference data from EGM2008 to ellipsoid using gdal
DA523
Post by DA523 »
by daniel » Mon Jul 03, 2023 10:36 am
What do you mean?
If we open UTM xyz , CC uses cartesian coordinates while UTM has curved Z reference axis (sea level) (earth curvature)
I sent you an email containing python code to prepare UTM coordinates to CC and reflect real shape
I hope you can check it
DA523
Post by DA523 »
What do you mean?
Suppose a ship travels inline with equator for a distance of 10000 km (earth circumference/4).
If z=0 y=0 and x from 0 to 10000 km
GPS coordinates are xyz in meters( UTM) and z is referenced to sea level which the same of earth curvature
CC represents track in straight line not curve
Can GDAL or other software prepare UTM to be represented in CC in real shape ?
utm to curve.png (34.27 KiB) Viewed 18390 times
DA523
Post by DA523 »
attached 3D pointscloud example
Screenshot (146).png (79.51 KiB) Viewed 18388 times
check CC file below
2500km.zip
(246.59 KiB) Downloaded 1990 times
DA523
Post by DA523 »
Let have these UTM coordinates (xyz in m) from a ship GPS log
x,y,z
468286,4082477,0
467995,3981250,0
467704,3880024,0
467413,3778797,0
467121,3677571,0
466830,3576345,0
466539,3475118,0
466248,3373892,0
465957,3272665,0
465665,3171439,0
465374,3070213,0
465083,2968986,0
464792,2867760,0
464501,2766533,0
464209,2665307,0
463918,2564081,0
463627,2462854,0
463336,2361628,0
463044,2260401,0
462753,2159175,0
462462,2057949,0
The real shape of ship track is ARC not straight line because earth curvature
GPS use z referenced to sea level (curved )
Because CC uses Cartesian coordinates ,it shows as straight line not curve line
Is there any existing software,lib which prepares utm to Cartesian so CC can show real curved line ? GDAL ?
GDAL would be my default guess but mainly because that's the only package I know :D
