Is is possible to smooth a section of points?
For instance, I have this anomaly in a terrain scan, is there a tool that will allow me to select and smooth these points relative to their neighbors?
- 2025-07-23_11h19_56.png (102.74 KiB) Viewed 35840 times
Re: Is is possible to smooth a section of points?
I've tried the MLS, SOR, and Noise filter on a segmentation of that area, but it always affects border points creating additional issues
Well, if the cloud is '2.5D', you could export the Z coordinates to a new SF, then smooth this SF (with the 'Edit > Scalar fields > Gaussian or Bilateral filters) and then convert this SF back to Z coordinates?
PablerasBCN
Also if it is 2.5 as said, if you call the rasterize tool and interpolate the voids and export the point cloud you may get what you're looking for.
