Using different fonts-->Serif Font
Ingsayyad
Post by Ingsayyad »
What is default font of CC? I want to use font 'Serif' for labeling. Is there any way to do it?
Re: Using different fonts-->Serif Font
We are using the 'default' system font I believe. Therefore you might be able to change it via the Windows 'style' parameters (not sure about that though).
Otherwise there's a mean to change it in the code (very simply), but you'll have to recompile it :D
Ingsayyad
Post by Ingsayyad »
I changed window font to time new roman and installed new CC, but still no change in font, Any idea?
If this doesn't work then the only solution is to hack the code for now...
