-DROP_GLOBAL_SHIFT not working?
Haax
Post by Haax »
Hello
If i run the line below in a cmd window, I get a .ply in the same coordinates as the original .dxf. Should'nt the exported .ply be in low/moved coordinates then?
If I remove the -DROP_GLOBAL_SHIFT flag I get the exact same result, does not seem like the -DROP_GLOBAL_SHIFT flag do anything at all.
-M_EXPORT_FMT PLY -PLY_EXPORT_FMT BINARY_LE -O -GLOBAL_SHIFT -442000 -6199000 0 myfile.dxf -DROP_GLOBAL_SHIFT -NO_TIMESTAMP -SAVE_MESHES
Regards
/Haax
Re: -DROP_GLOBAL_SHIFT not working?
Ha! I think I know what's going on. Let me check something and I'll get back to you.
No, it was not what I thought... It works on my side.
Can you maybe share the DXF file with me? (cloudcompare [at] danielgm.net)
Haax
Post by Haax »
Thank's for your quick help
You've got an e-mail now
And by the way, thank's for the hard work on a really great program.
/Haax
Ok the culprit was the DXF loader (which was wrongly locking the vertices) and another internal test that was too restrictive when handling locked vertices...
I'll try to update the online version soon. I'll keep you updated.
Ok the online 2.8 beta has just been updated. Thanks for the feedback.
Haax
Post by Haax »
Wow, quick work, will try it right away and see if it works.
Haax
Post by Haax »
Thank's Daniel
Worked as expected.
One strange thing though, i could not just use the dxf-name any longer. Had to put the whole path in.
Regards
/Haax
Yes, I think that there has been a change in the default path (it was necessary for the Mac version I believe).
