File overwritten in command line mode
stahl
Post by stahl »
Hello there,
I want to split one e57 file containing multiple scans into multiple e57 files.
I am using
CloudCompare -O file.e57 -C_EXPORT_FMT E57 -SAVE_CLOUDS
for this.
Now to the problem: CloudCompare is too fast and overwrites the file, because it gets the same timestamp.
Is there an option I didn't see like a counter instead of timestamps?
Thanks in advance and thanks for all your hard work!
stahl
Re: File overwritten in command line mode
Never thought someone will complain about that ;)
I'm joking, this is a bad 'feature' indeed :D. I'll see what I can do.
Okay, that's "fixed" (the timestamp now incorporates milliseconds). You can test the latest beta release online.
