Crop2D command line using existing polyline (imported shapefile)
adams
Post by adams »
I would like to Crop2D loaded mesh by existing shapefile (imported earlier), using command line mode. Is it possible to choose existing polyline instead of number and coordinates of vertices?
import os, subprocess
CCPath = r"C:\Program Files\CloudCompare"
filePath = r"E:\AS\Agi_skrypt\mesh_cc.ply"
shpPath = r"E:\AS\Agi_skrypt\obszar_cc.shp"
os.chdir(CCPath)
openFile=os.system("CloudCompare -AUTO_SAVE OFF -O " + filePath " + "-CROP2D Z " + shpPath)
Update: I have vertices coordinates from shapefile, but when i try to launch this function this error appears:
"No point cloud availabe...". Does it mean that this function works only on pointclouds? :( i cropped meshes in this way using GUI version of CC.
Best regards,
Adam
Re: Crop2D command line using existing polyline (imported shapefile)
Indeed, as the method description seems to indicate, it only works on clouds ;)
adams
Post by adams »
I found out a solution for my problem. I generate point cloud from my mesh :)
I have an another problem... namely i can't specify filename of resulted mesh.
openFile=os.system("CloudCompare -AUTO_SAVE OFF -O " + filePath +" " + "-SAMPLE_MESH POINTS 100000 -CROP2D Z " + coordinates + "-CLEAR_MESHES -DELAUNAY -AUTO_SAVE OFF -CLEAR_CLOUDS -M_EXPORT_FMT PLY -SAVE_MESHES FILE mask.ply")
I'm using CC in version 2.10alpha and according to http://www.cloudcompare.org/doc/wiki/in ... _line_mode it is possible to spefify exported mesh/meshes.
That's a bit strange. Do you have some warning messages in the console maybe?
Just as a remark, I don't think you need to add the "-AUTO_SAVE OFF" statement two times. Same thing for the "-CLEAR_CLOUDS" (not sure it's necessary here).
