File seems to be corrupted
Maja
Post by Maja »
Was working with CC, when the computer froze completely. Had to restart it using the button. Before restarting, the system gave me the option to save and close open applications/docs. I tried to save the work in CC, but the process was running and running, so I stopped it (Task Manager), restart the comp and when I tried to open the bin file (I was saving previously) I get the message:
[18:22:39] File seems to be corrupted
[18:22:39] An error occurred while loading 'a1': see console
Is the BIN file lost and all the work?
Thanks for the answer!
Best,
Maja
Re: File seems to be corrupted
Well, it happens when killing the application while it is saving the file :-|
How big is the file? I could maybe try to save a part of it if you send it to me.
mpm
Post by mpm »
I have the same problem...Is there any way to recover the file? Thanks
antonellam2
Post by antonellam2 »
have you solved this problem? I have the same
As my answer above was implying, only by tinkering with the file would I be able to recover something from a corrupted file (maybe, if you are lucky). But for that I need the file.
