Where to find the maximal error after C2C or C2M analysis
pochihlee
Post by pochihlee »
Hi All,
I would like to know how to find out where the maximal error located in my model after I compare two objects using C2C or C2M methods.
After the comparison, the color on the object can only roughly tell us the errors on it. However, if I want to the exact location that the maximal error happens, what should I do?
Thank you for the reply.
Po
Re: Where to find the maximal error after C2C or C2M analysis
You can play with the minimum displayed (distance) value of the active distance scalar field so as to visually isolate it:
Alternatively you can use the 'Edit > Scalar field > Filter by value' tool to extract the point with the maximum distance.
