properties not showing
max72
Post by max72 »
I installed last stable and last alpha, but in both cases "properties" is not showing.
Right clicking on the toolbar area shows propereties greyed out.
I cannot find where activate it anymore.
Any help is appreciated.
Thanks in advance,
Massimo
Re: properties not showing
Can you try to 'reset' the GUI elements? (Display > Reset all GUI elements)
max72
Post by max72 »
Thanks!
It fixed the issue.
I have two monitors and let the DB tree and properties floating the secondary monitor. It probably moved in some hidden areas.
Thanks again,
Massimo
