Losing data on LAS export
bcox
Post by bcox »
Hi, I'm new to CC so this may not be an actual bug, but I'm having an issue exporting .las files. I'm trying to use the Multiply/Scale tool to scale some mobile LiDAR point cloud files from grid to surface by a scale factor, but I'm losing the overwhelming majority of my points upon export (ex: one file originally has +/- 27,000,000 points; after export it only has +/- 2,000,000). All of the points import into CC, so I know they're coming in fine. I have tried using both the highest and original resolutions of the data on export. Is this an issue with the Global Shift, or a setting I need to change before I export?
Re: Losing data on LAS export
Which version are you using? And what scale factor are you applying typically?
