Export Cylinder Parameters
muzo583
Post by muzo583 »
Dear Daniel,
I am fitting cylinders to point clouds. But I wonder, is there a way to export all cylinders parameters to ascii file?
Similar to;
x,y,z, directions(x,y,z), radius.
From gui or command line?
Thanks.
Mustafa
Re: Export Cylinder Parameters
Nope, not right now. You would have to hack the existing code of CloudCompare (typically the 'Tools > Batch export > Export cloud info" function).
muzo583
Post by muzo583 »
This function is also enough for me.
I can handle after it.
Thank you.
