Export contour lines as shp with values
foxx1
Post by foxx1 »
I created contour lines of a point cloud and exported them as a shapefile to open it in ArcMap. It opens successfully but I can't find any height values in the attribute table of the exported shape. My question is: How can export contour lines as .shp with height values included?
Thank you in advance
foxx1
Re: Export contour lines as shp with values
Which tool did you use to extract the contour?
foxx1
Post by foxx1 »
Hello Daniel,
I used File --> Save and then choosed .shp
No, I meant to "compute/create" the contour polyline?
foxx1
Post by foxx1 »
Hello Daniel,
Tools --> Projection --> Rasterize --> Contour Plot --> Generate --> Export --> Close
Afterwards I save the contour plot as a .shp file.
Greetings
foxx1
Have you selected the right options?
foxx1
Post by foxx1 »
Thank you! :-) I forgot to select the option you mentioned in the screenshot...
