Crop- force inside
barney2074
Crop- force inside
Post by barney2074 »
When using the commandline -CROP option, I have noticed that if no points fall inside the defined box, then the whole pointcloud is exported, rather than no points
In my case, I have a large number of boxes which I am applying to various point clouds- and working out if a particular pointcloud has points within a particular box is not easy.
I would just like to run a batchfile with the commandline options, and if there are no points for that box, then just get an empty file (no points)
Is there any way to force Cloudcompare to do this ?
thanks
Andrew
Re: Crop- force inside
Hum, indeed I believe this is because if no cloud is output by the CROP command, the previously loaded cloud are not replaced by the (non existent) new cloud and they remain loaded...
I guess we can indeed change the behavior. Stay tuned.
barney2074
thanks Daniel
Cloudcompare is just an awesome application- puts many of the commercial applications to shame...!
Andrew
The 2.11.alpha (non stereo) version online has been updated!
barney2074
Hi Daniel
thank you so much for making this change so quickly, and for Cloudcompare itself.
Cloudcompare really is a fantastic application.
I have tested and it works great. I see the following message:
20191114 cloudcompare crop.PNG (3.86 KiB) Viewed 4775 times
Andrew
Which command did you use exactly?
