I need to generate an approximate extent in plan of a number of pointclouds.
The method works outlined below, but is quite laborious and slow.
I was wondering if anyone had a quicker method ?
>create a new constant SF and set to zero
>set this SF as the z coordinate (flattens all points)
>resample
>create a polyline section at z=0
>export as a dxf
thanks
Andrew
extent or perimeter of pointcloud
Re: extent or perimeter of pointcloud
Can you try instead the 'Tools > Fit > Facet' method?
To build a 'facet', CC will try to extract the concave 'contour' which is a polyline and can be exported directly to DXF (the facet is actually a composition of several entities).
Maybe you'll need to flatten the point cloud first (depending on how the resulting facet orientation). This can be done more quickly with the 'Edit > Multiply / Scale' (set the Z scale to 0).
barney2074
thanks Daniel, that is certainly much quicker
Andrew
Andrew
