Hi, I've searched without luck so I guess this functionality is missing.
I would need to extract the bounding yellow spline that is displayed in the 3d view, as shown in top view with ortographic, this is to segment this area from another cloud with less resolution
For now you can only read the bounding-box center and dimensions in the cloud properties... and then do the math to deduce were the corners are! (or use the 'Edit > Crop' tool directly, where you can input the center + dimensions).
Hello, thank you, yes looks like a good idea. I can draw the points in CAD and export back as shp. I remember in the past importing shp for triming clouds.
Yep exactly that, the actually visible yellow bounding box converted to Spline , just the square/rectangle seen from above converted to a poliline I could use later on with the segment tool :D
