Filter
satanmar
Filter
Post by satanmar »
is there any simple way, please, how to filter following data:
I have two pointclouds which have overlap, but there are in different step of construction (before and after shotcreting). I would like to combined them and filter for example the cloud before shotcreting (outer conbtour). Difference between the layers are aprox. from 0 to 8 cm, therefor this overlap is hard to clean Center line and profiles are available. Thanks for any advice.
Re: Filter
I'm not sure to understand: what do you mean by 'filter'? Remove some points? Then why aren't you doing it before merging the clouds? (this is why I'm quite sure I miss something ;)
