I flattened a mesh by scaling z to 0
I need to find MESH FLAT AREA
Please check attached STL file
How to find area of flat mesh?
- area.zip
- (979 Bytes) Downloaded 456 times
Re: How to find area of flat mesh?
Have you tried the 'Edit > Mesh > Measure surface' tool? (it should work fine as long as the triangles are not overlapping each other after the mesh has been 'flatten').
(on your example mesh, it gave me 1260.28 square units)
Yes this is exactly the solution
Thank you
Thank you
