Which PCL version supported
flan
Post by flan »
I checked the documentation about the pcl plugin. It says PCL 1.6 is supported on linux, but this version is very old. I didn't find the correct version for installation.
Could you specify which version of PCL library is supported on linux?
Thanks!
Re: Which PCL version supported
That's maybe more a question to ask on github (where you will find more developers ;) but I believe it should work the same as on Windows? (i.e. at least version 1.12).
