Hi, there
I have been used CC in Windows and tried to use it in Linux vm (GCP Ubuntu) by compiling from the sources. All worked smoothly but when I try to create meshes from point clouds, I had an issue with "Triangle Lib error: CGAL library not supported". See the attached images of error messages. I already had CGAL libraries installed.
Do I need to do something during compiling with specific options as we do for additional plugins? Or something else is missing. Thanks.
Regards,
Kwang-Ho
Mesh error in CC in Linux enviroment
- CC_mesh_errors_Linux_2.jpg (36.69 KiB) Viewed 2208 times
- CC_mesh_errors_Linux_1.jpg (19.97 KiB) Viewed 2208 times
Re: Mesh error in CC in Linux enviroment
I believe this is related to https://github.com/CloudCompare/CloudCo ... 1037239693
