Statistic of distance between points in point cloud
nytu
Post by nytu »
Hi! is it possible to calculate the statistics of the distances between points in CloudCompare? E.g. by triangulation or separation of rows?
Re: Statistic of distance between points in point cloud
Hum, not sure to understand at which kind of statistics you are referring to... You can simply compute the histogram of the values, as well as the mean, standard deviation and RMS of the values.
But you can also export the values (and the point coordinates) by exporting the cloud as an ASCII/CSV file. So as to be able to process the values in another software.
