CloudCompare Versions
mcaradonna
Post by mcaradonna »
I have v2.13.3.beta downloaded, and am trying to use the command line mode
I want to use -GLOBAL_SHIFT Auto. But it says the command is not recognized. Basically just trying to automate the automatic global shift that is provided when you open a .las file.
The wiki says that I need v2.3, but I cannot find that version while downloading.
Re: CloudCompare Versions
What's your full command? -GLOBAL_SHIFT can only be placed after -O
mcaradonna
cloudCompareCommand = ['"C:\Program Files\CloudCompare\cloudcompare.exe" -AUTO_SAVE OFF ', ...
    '-C_EXPORT_FMT LAS -O "', inputFile '" ', ...
    '-GLOBAL_SHIFT AUTO "' '" ', ...
    '-SAVE_CLOUDS FILE "', outputFile '"'];
So yes, you have to put '-GLOBAL_SHIFT' right after '-O'.
