error "Render to File"
fbp
Post by fbp »
I think there is a problem with the graphic scale that is generated when the "Render to File" command is executed.
I am obtaining vertical sections of a model and when saving the frontal capture I do not get a scale elevation. In the image obtained, the measurement that appears is exactly 25% larger than the corresponding one (for 4 m a graphic scale of 5 m appears, and for 8 m it appears 10 m), do you know if there is any error?
CloudCompare Kharkiv version 2.13.1
Re: error "Render to File"
Did you use a 'zoom' factor maybe? And was the projection mode 'orthographic' or 'projective'?
fbp
Post by fbp »
The system used is orthographic with an adequate zoom to obtain the necessary resolution
Sorry for the late reaction, I was travelling.
I'll have to try to reproduce this issue on my side first...
fbp
Post by fbp »
Thanks for the comunication.
I have reviewed the problem and it seems that it is motivated by the size of the graphic scale, the image shows a value one meter higher than the corresponding one, thus for 4 m it appears 5 m (25% larger).
Hum, I think I've managed to reproduce it. This seem to only happen when the height of the screen is higher than the width.
Ok, this should be fixed in the next 2.13.2 release. You can find the preview here: https://www.cloudcompare.org/release/Cl ... up_x64.exe
