I really hope someone can help me here.
Here's the environment I'm running on a MacBook with Apple M1 silicon running Sequoia 15.3.1.
THE PROBLEM: I am unable to save ANY file from CC.
Here is the error message I get in the log window:
[16:29:11] An error occurred while saving '/Users/KenJacobMacbook/QGIS/LiDAR/temp test folder/USGS_LPC_CT_Statewide_C16_830905_nw_lasheight.laz': the third-party library in charge of saving/loading the file has failed to perform the operation
This error occurs if all I do is open a .laz file from the USGS website, do nothing to it, and then try to save it to a new file. And it happens to ALL other point clouds I've processed in CC (wonderfully, by the way -- very happy with what I can do in this program.)
I've attached the state of the save dialog box (I didn't change anything) in case that's helpful.
HELP PLEASE!!!
Sincerely,
Ken
Can't save .las/.laz files on Mac
- Screenshot 2025-03-08 at 4.28.13 PM.jpg (144.38 KiB) Viewed 57904 times
- Screenshot 2025-03-08 at 4.27.52 PM.jpg (125.79 KiB) Viewed 57904 times
Re: Can't save .las/.laz files on Mac
I guess it's related to the github issue?
I'm also concerned that the 2.13 version is getting quite old. We should ask Paul Rascle to create a new binary with the latest 2.14.alpha version...
After upgrading to macos 15.4, all the buttons to open, save and save as are not working. Also cmd+s isn't working. There is no way to save data out of cloudcompare, I tried with these builds "CloudCompare_20250314_161011.dmg" and "CloudCompare_2.13.2__arm64.dmg"
I just built 2.14.alpha from source and the problem I still there. I can't save anything!!
Isn't it different from the initial message? Because at that time the LAS saving dialog was visible...
Anyway, macOS is a different world. So maybe now that you have compiled the project there (good job by the way), you can debug things a little bit?
Sadly the build was a little broken, so I got rid off it. However, from the git issue a tip that worked for mac is to disable "Use native load / save dialog box" from display settigns.
andytrench
I had a problem with 2.14 where i couldn't get the native open dialogue to work at all and i really needed it to work for my current workflow.
Checking the native dialogue box in settings did nothing.
So i have vibe-coded my way into a working version using the augment ai plugin for VS CODE... (I'm using augment over cursor these days and its kicking butt)
My setup:
M2 Macbook pro
Sequoia 15.1.1
I now have a working 2.14 with native file open dialogue so i'll share the readme to the fix here in case it can help someone else.
## Changes Made
1. **Added Bundle Identifier**: Updated `qCC/Mac/CMakeLists.txt` to include the `MACOSX_BUNDLE_GUI_IDENTIFIER` property with the value "org.cloudcompare.CloudCompare".
2. **Added macOS Native Dialog Option**: Added a new option `forceMacOSNativeDialogs` to the `ccOptions` class to specifically force native dialogs on macOS, overriding the general `useNativeDialogs` setting.
3. **Updated File Dialog Options**: Modified the `CCFileDialogOptions` function in `mainwindow.cpp` to use the `forceMacOSNativeDialogs` option on macOS.
## Manual Changes Required
If the automatic script didn't update all files correctly, you'll need to manually make the following changes:
### 1. Update qCC/Mac/CMakeLists.txt
Add the `MACOSX_BUNDLE_GUI_IDENTIFIER` property to the `set_target_properties` command:
```cmake
set_target_properties( ${PROJECT_NAME} PROPERTIES
INSTALL_RPATH "@executable_path/../Frameworks"
MACOSX_BUNDLE_INFO_PLIST ${CMAKE_CURRENT_SOURCE_DIR}/CloudCompare.plist
MACOSX_BUNDLE_ICON_FILE cc_icon.icns
MACOSX_BUNDLE_GUI_IDENTIFIER "org.cloudcompare.CloudCompare"
MACOSX_BUNDLE_SHORT_VERSION_STRING "${PROJECT_VERSION}"
MACOSX_BUNDLE_LONG_VERSION_STRING "${PROJECT_VERSION}"
MACOSX_BUNDLE_BUNDLE_VERSION "${PROJECT_VERSION}" )
### 2. Update libs/CCAppCommon/include/ccOptions.h
Add the `forceMacOSNativeDialogs` option to the `ccOptions` class:
```cpp
//! Force native dialogs on macOS (overrides useNativeDialogs)
bool forceMacOSNativeDialogs;
### 3. Update libs/CCAppCommon/src/ccOptions.cpp
Initialize the `forceMacOSNativeDialogs` option in the `reset` method:
```cpp
void ccOptions::reset()
normalsDisplayedByDefault = false;
useNativeDialogs = true;
forceMacOSNativeDialogs = true;
confirmQuit = true;
Add the `forceMacOSNativeDialogs` option to the `fromPersistentSettings` method:
```cpp
void ccOptions::fromPersistentSettings()
QSettings settings;
settings.beginGroup(ccPS::Options());
normalsDisplayedByDefault = settings.value("normalsDisplayedByDefault", false).toBool();
useNativeDialogs = settings.value("useNativeDialogs", true).toBool();
forceMacOSNativeDialogs = settings.value("forceMacOSNativeDialogs", true).toBool();
confirmQuit = settings.value("confirmQuit", true).toBool();
settings.endGroup();
Add the `forceMacOSNativeDialogs` option to the `toPersistentSettings` method:
```cpp
void ccOptions::toPersistentSettings() const
QSettings settings;
settings.setValue("normalsDisplayedByDefault", normalsDisplayedByDefault);
settings.setValue("useNativeDialogs", useNativeDialogs);
settings.setValue("forceMacOSNativeDialogs", forceMacOSNativeDialogs);
settings.setValue("confirmQuit", confirmQuit);
### 4. Update qCC/mainwindow.cpp
Replace the `CCFileDialogOptions` function with the following implementation:
```cpp
static QFileDialog::Options CCFileDialogOptions()
//dialog options
QFileDialog::Options dialogOptions = QFileDialog::Options();
dialogOptions |= QFileDialog::DontResolveSymlinks;
#ifdef Q_OS_MAC
// On macOS, always use native dialogs if the option is enabled
if (!ccOptions::Instance().useNativeDialogs && !ccOptions::Instance().forceMacOSNativeDialogs)
dialogOptions |= QFileDialog::DontUseNativeDialog;
#else
// On other platforms, follow the general setting
if (!ccOptions::Instance().useNativeDialogs)
#endif
return dialogOptions;
## Building CloudCompare
After making these changes, build CloudCompare as usual:
```bash
mkdir -p build
cd build
cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/Applications
make -j$(sysctl -n hw.ncpu)
make install
This will create a properly bundled CloudCompare application with the native file dialog fix.
Additional context
#!/bin/bash
# Apply macOS fixes to CloudCompare
# Define paths
CC_DIR="CloudCompare"
cd "$CC_DIR" || { echo "CloudCompare directory not found"; exit 1; }
# 1. Update the Mac CMakeLists.txt to include the bundle identifier
echo "Adding bundle identifier to qCC/Mac/CMakeLists.txt"
cat > qCC/Mac/CMakeLists.txt << 'EOF'
# Put together our App bundle on macOS
if( APPLE )
set( CLOUDCOMPARE_MAC_BASE_DIR ${CMAKE_INSTALL_PREFIX}/${CLOUDCOMPARE_DEST_FOLDER}/CloudCompare.app CACHE INTERNAL "CloudCompare bundle dir")
set( CLOUDCOMPARE_MAC_FRAMEWORK_DIR ${CLOUDCOMPARE_MAC_BASE_DIR}/Contents/Frameworks CACHE INTERNAL "CC framework dir" )
set( CLOUDCOMPARE_MAC_PLUGIN_DIR ${CLOUDCOMPARE_MAC_BASE_DIR}/Contents/PlugIns/ccPlugins CACHE INTERNAL "CC plugin dir" )
# install icons
install( FILES cc_icon.icns DESTINATION ${CLOUDCOMPARE_MAC_BASE_DIR}/Contents/Resources COMPONENT Runtime )
endif( APPLE )
EOF
# 2. Update the ccOptions.h file to add the macOS native dialog option
echo "Updating ccOptions.h to add macOS native dialog option"
if [ -f "libs/CCAppCommon/include/ccOptions.h" ]; then
# Add the new option to the existing file
sed -i.bak '/bool useNativeDialogs;/a\\n\t\/\/! Force native dialogs on macOS (overrides useNativeDialogs)\n\tbool forceMacOSNativeDialogs;' libs/CCAppCommon/include/ccOptions.h
else
echo "ccOptions.h not found"
exit 1
fi
# 3. Update the ccOptions.cpp file to implement the macOS native dialog option
echo "Updating ccOptions.cpp to implement macOS native dialog option"
if [ -f "libs/CCAppCommon/src/ccOptions.cpp" ]; then
# Add initialization for the new option
sed -i.bak 's/useNativeDialogs = true;/useNativeDialogs = true;\n\tforceMacOSNativeDialogs = true;/' libs/CCAppCommon/src/ccOptions.cpp
# Add the new option to the settings loading
sed -i.bak '/useNativeDialogs = settings.value("useNativeDialogs", true).toBool();/a\\t\tforceMacOSNativeDialogs = settings.value("forceMacOSNativeDialogs", true).toBool();' libs/CCAppCommon/src/ccOptions.cpp
# Add the new option to the settings saving
sed -i.bak '/settings.setValue("useNativeDialogs", useNativeDialogs);/a\\t\tsettings.setValue("forceMacOSNativeDialogs", forceMacOSNativeDialogs);' libs/CCAppCommon/src/ccOptions.cpp
else
echo "ccOptions.cpp not found"
exit 1
fi
# 4. Update the CCFileDialogOptions function in mainwindow.cpp
echo "Updating CCFileDialogOptions function in mainwindow.cpp"
if [ -f "qCC/mainwindow.cpp" ]; then
# Create a temporary file with the new function
cat > /tmp/CCFileDialogOptions.txt << 'EOF'
//dialog options
#ifdef Q_OS_MAC
#else
#endif
EOF
# Find the function in the file
LINE_START=$(grep -n "static QFileDialog::Options CCFileDialogOptions()" qCC/mainwindow.cpp | cut -d':' -f1)
if [ -z "$LINE_START" ]; then
echo "Could not find CCFileDialogOptions function in mainwindow.cpp"
exit 1
fi
# Find the end of the function (the closing brace)
LINE_END=$((LINE_START + 10)) # Assuming the function is about 10 lines long
while [ $LINE_END -lt $(wc -l < qCC/mainwindow.cpp) ]; do
if grep -q "^}" <(sed -n "${LINE_END}p" qCC/mainwindow.cpp); then
break
fi
LINE_END=$((LINE_END + 1))
done
# Replace the function with our new implementation
sed -i.bak "${LINE_START},${LINE_END}c\\$(cat /tmp/CCFileDialogOptions.txt)" qCC/mainwindow.cpp
else
echo "mainwindow.cpp not found"
exit 1
fi
echo "macOS fixes applied successfully!"
echo ""
echo "To build CloudCompare with these changes, you need to:"
echo "1. Install Qt5 on your system"
echo "2. Configure the build with CMake, pointing to your Qt5 installation:"
echo " mkdir -p build"
echo " cd build"
echo " cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/Applications -DQt5_DIR=/path/to/Qt5/lib/cmake/Qt5"
echo "3. Build and install CloudCompare:"
echo " make -j$(sysctl -n hw.ncpu)"
echo " make install"
Additional Fixes Explanation
# CloudCompare macOS Build Fixes
This document outlines the fixes required to build CloudCompare on macOS systems.
## Common Build Issues and Solutions
### 1. Missing `forceMacOSNativeDialogs` Variable
**Issue**: The `forceMacOSNativeDialogs` variable is used in `ccOptions.cpp` but not declared in `ccOptions.h`.
**Fix**: Add the variable declaration to `ccOptions.h`:
```cpp
// In CloudCompare/libs/CCAppCommon/include/ccOptions.h
// Add after the useNativeDialogs declaration:
### 2. Indentation Issues in ccOptions.cpp
**Issue**: The `ccOptions.cpp` file has incorrect indentation, which can cause build errors.
**Fix**: Ensure proper indentation throughout the file. For example:
```cpp
// Before:
confirmQuit = true;
// After:
confirmQuit = true;
### 3. Preprocessor Directive Errors in mainwindow.cpp
**Issue**: The `mainwindow.cpp` file contains duplicate preprocessor directives (`#else` and `#endif` without matching `#if` statements).
**Fix**: Remove the duplicate directives and ensure proper pairing of preprocessor statements:
```cpp
// Correct structure:
#ifdef Q_OS_MAC
#else
#endif
## Building CloudCompare on macOS
After applying the fixes above, follow these steps to build CloudCompare:
1. Create a build directory:
```bash
mkdir build && cd build
2. Configure with CMake:
```bash
cmake -DCMAKE_PREFIX_PATH=/path/to/qt ..
Note: If using Homebrew-installed Qt, the path might be `/usr/local/opt/qt@5` or similar.
3. Build the project:
```bash
4. Run CloudCompare:
```bash
open qCC/CloudCompare.app
## Additional macOS-Specific Notes
1. **Qt Version**: CloudCompare 2.13+ requires 5.12 <= Qt < 6.0.
2. **Native Dialogs**: The `forceMacOSNativeDialogs` option ensures that native file dialogs are used on macOS, which provides a better user experience.
3. **Development Paths**: If you are compiling and running locally, add `-DCC_MAC_DEV_PATHS` to the `CMAKE_CXX_FLAGS` in the `CMAKE` group. This will look for plugins in your build directory rather than the application bundle.
4. **Portable Build**: For a portable (relocatable) build, consider using the `pixi` build system as mentioned in the main BUILD.md file.
## Troubleshooting
If you encounter issues with running the built application:
1. **Library Path Issues**: Ensure that all required libraries are properly linked and can be found at runtime.
2. **Plugin Loading**: Check that plugins are correctly built and placed in the expected directories.
3. **Qt Framework**: Verify that the Qt frameworks are correctly bundled with the application or accessible in the system.
4. **Code Signing**: For distribution, you may need to properly code sign the application.
My setup:
M2 Macbook pro
Sequoia 15.1.1
## Changes Made
```cmake
```cpp
```cpp
confirmQuit = true;
```cpp
QSettings settings;
```cpp
QSettings settings;
```cpp
//dialog options
#ifdef Q_OS_MAC
#else
#endif
```bash
mkdir -p build
cd build
make install
Additional context
#!/bin/bash
# Define paths
if( APPLE )
# install icons
endif( APPLE )
EOF
else
exit 1
fi
else
exit 1
fi
//dialog options
#ifdef Q_OS_MAC
#else
#endif
EOF
exit 1
fi
break
fi
done
else
exit 1
fi
echo ""
echo " cd build"
```cpp
```cpp
// Before:
confirmQuit = true;
// After:
confirmQuit = true;
```cpp
#ifdef Q_OS_MAC
#else
#endif
```bash
```bash
```bash
```bash
## Troubleshooting
Thanks, I've linked your message on the git issue discussion: https://github.com/CloudCompare/CloudCo ... ssues/2152
I'm curious if there's been any progress on this issue?
Has there been progress on this issue? How can I help move this forward? It is kind of a major issue for MAC users, like crippling us.
