Nov beta can not open BIN saved by Sep version
DA523
Post by DA523 »
latest Nov beta can not open BIN saved by Sep version
Re: Nov beta can not open BIN saved by Sep version
Would you be able to share the BIN file saved with the September version with me? ([email protected])
DA523
Post by DA523 »
Same, November beta ver can not open BIN saved by stable v2.13.2 (utm pc)
Screenshot 2025-11-15 173437.png (14.49 KiB) Viewed 53716 times
DA523
Post by DA523 »
Attached example file
SAVED BY v2.13.2.zip
(1.85 KiB) Downloaded 2253 times
Hum, looks more like a corrupted file than anything else... I haven't been able to reproduce the issue on my side sadly.
Did you use the official 2.13.2 version on Windows?
And was it just a simple point cloud inside this file? Maybe with a color scale that has labels? If yes, do you still have the same issue if you remove the color scale and save the file again?
DA523
Post by DA523 »
It not corrupted file
I can reproduce it many of times
The attached file can be opened by v2.13.2 but not November beta
Ok, it seems to impact files that have VLRs meta-data (so with a point loaded from a LAS file).
I've patched the Windows version online (16 Nov.) so as to skip the loading of this particular type of meta-data until we find a fix.
