qCC_io version 2.13.alpha (Qt) - 31 May 2022
CloudCompare standard I/O filters (file readers & writers)
This is the complete list of members for ccGlobalShiftManager, including all inherited members.
| ALWAYS_DISPLAY_DIALOG enum value (defined in ccGlobalShiftManager) | ccGlobalShiftManager | |
| BestScale(double d) | ccGlobalShiftManager | static |
| BestShift(const CCVector3d &P) | ccGlobalShiftManager | static |
| DIALOG_IF_NECESSARY enum value (defined in ccGlobalShiftManager) | ccGlobalShiftManager | |
| GetLast() | ccGlobalShiftManager | static |
| Handle(const CCVector3d &P, double diagonal, Mode mode, bool useInputCoordinatesShiftIfPossible, CCVector3d &coordinatesShift, bool *_preserveCoordinateShift=nullptr, double *_coordinatesScale=nullptr, bool *_applyAll=nullptr) | ccGlobalShiftManager | static |
| LoadInfoFromFile(QString filename, std::vector< ShiftInfo > &infos) | ccGlobalShiftManager | static |
| MAX_COORDINATE_ABS_VALUE (defined in ccGlobalShiftManager) | ccGlobalShiftManager | protectedstatic |
| MAX_DIAGONAL_LENGTH (defined in ccGlobalShiftManager) | ccGlobalShiftManager | protectedstatic |
| MaxBoundgBoxDiagonal() | ccGlobalShiftManager | inlinestatic |
| MaxCoordinateAbsValue() | ccGlobalShiftManager | inlinestatic |
| Mode enum name | ccGlobalShiftManager | |
| NeedRescale(double d) | ccGlobalShiftManager | static |
| NeedShift(const CCVector3d &P) | ccGlobalShiftManager | static |
| NeedShift(double d) | ccGlobalShiftManager | static |
| NO_DIALOG enum value (defined in ccGlobalShiftManager) | ccGlobalShiftManager | |
| NO_DIALOG_AUTO_SHIFT enum value (defined in ccGlobalShiftManager) | ccGlobalShiftManager | |
| SetMaxBoundgBoxDiagonal(double value) | ccGlobalShiftManager | inlinestatic |
| SetMaxCoordinateAbsValue(double value) | ccGlobalShiftManager | inlinestatic |
| StoreShift(const CCVector3d &shift, double scale, bool preserve=true) | ccGlobalShiftManager | static |
