Helper class to handle big coordinates shift/scale (typically while loading entities)
More...
#include <ccGlobalShiftManager.h>
| enum | Mode { NO_DIALOG
, NO_DIALOG_AUTO_SHIFT
, DIALOG_IF_NECESSARY
, ALWAYS_DISPLAY_DIALOG
| | Strategy to handle coordinates shift/scale.
static bool | Handle (const CCVector3d &P, double diagonal, Mode mode, bool useInputCoordinatesShiftIfPossible, CCVector3d &coordinatesShift, bool *_preserveCoordinateShift=nullptr, double *_coordinatesScale=nullptr, bool *_applyAll=nullptr) |
| | Handles coordinates shift/scale given the first 3D point and current related parameters.
static bool | NeedShift (const CCVector3d &P) |
| | Returns whether a particular point (coordinates) is too big or not.
static bool | NeedShift (double d) |
| | Returns whether a particular point coordinate is too big or not.
static bool | NeedRescale (double d) |
| | Returns whether a particular dimension (e.g. diagonal) is too big or not.
static CCVector3d | BestShift (const CCVector3d &P) |
| | Suggests a shift for a given point expressed in global coordinate space.
static double | BestScale (double d) |
| | Suggests a scale for a given dimension (e.g. diagonal) in global coordinate space.
static double | MaxCoordinateAbsValue () |
| | Returns the max coordinate (absolute) value.
static void | SetMaxCoordinateAbsValue (double value) |
| | Sets the max coordinate (absolute) value.
static double | MaxBoundgBoxDiagonal () |
| | Returns max bounding-box diagonal.
static void | SetMaxBoundgBoxDiagonal (double value) |
| | Sets the max bounding-box diagonal.
static void | StoreShift (const CCVector3d &shift, double scale, bool preserve=true) |
| | Adds a new shift / scale couple.
static const std::vector< ShiftInfo > & | GetLast () |
| | Returns the default and last input shift/scale entries.
| static bool | LoadInfoFromFile (QString filename, std::vector< ShiftInfo > &infos) |
| | Tries to load ShiftInfo data from a (text) file. More...
static double | MAX_COORDINATE_ABS_VALUE = 1.0e4 |
static double | MAX_DIAGONAL_LENGTH = 1.0e6 |
◆ LoadInfoFromFile()
| bool ccGlobalShiftManager::LoadInfoFromFile |
QString |
filename, |
infos |
static |
- Parameters
| [in] | filename | filename |
| [out] | infos | read information |
- Returns
- success
- ccGlobalShiftManager.h
- ccGlobalShiftManager.cpp
