Mesh Boolean (plugin)
It is based on the libigl library.
- select two meshes (meshes should be ideally closed, otherwise the output might be wrong)
- click on the plugin icon (or the equivalent entry in the 'Plugins' menu: 'Plugins > Mesh Boolean Operations')
- when the plugin dialog appears (see above):
- assign each mesh to a role (A or B)
- then select the operation to apply:
- union: A + B
- difference (symmetric or not): A - B
- intersection: A n B
This plugin is very similar to the Cork plugin. It is however slower but supposedly more robust.
