Remove duplicate points
This tool is accessible via the 'Tools > Other > Remove duplicate points' menu.
This tool removes duplicate points (with respect to a minimal distance between points) in a point cloud.
Select one or several points clouds then start this tool.
CloudCompare will only ask for the minimum distance between points (with a ridiculously small value by default):
On completion CloudCompare will output in the console the number of duplicate points removed (or a message stating that the cloud 'has no duplicate points').
