Scalar fields\Set SF as coordinate(s)
This tool is accessible via the 'Edit > Scalar fields > Set SF as coordinate(s)' menu entry.
Sets the active scalar field of the selected cloud as one (or several) of its coordinates.
CloudCompare will ask the user to select the destination dimension(s):
Edit > Scalar Fields > Set SF as coordinate(s) dialog
For instance one can replace the Z coordinates by any scalar value so as to have a kind of '3D representation' of the scalar field. More commonly, this method is useful to convert a 2D raster with the altitude coming as scalar field into a proper 3D cloud/raster.
Left: original raster - right: Z coordinate 'exported' the from associated SF
Note: it is sometimes necessary to rescale the Z coordinate afterwards (with the Multiply/Scale method) as raster fields are not always in the same units as the XY coordinates (e.g. the altitude is coded as a gray intensity, between 0 and 255).
