Scalar fields\Split cloud (integer values)
This tool is accessible via the 'Edit > Scalar fields > Split cloud (integer values)' menu entry.
This tool will split the cloud in as many different (integer) values that are present in the active scalar field. This is primarily designed to split a cloud in all the individual classes of a 'Classification' scalar field.
  • the highlighted cloud(s) will be disabled, and new clouds will be created (for each integer value found)
  • caution, don't use this tool on a scalar field with too many different values...
